24,000 Desmo Service
Discussion in 'Scrambler Talk' started by Phil McAvity, Jun 18, 2017.
  1. Phil McAvity
    Phil McAvity Member
    Sep 9, 2016
    31
    17
    8
    Bangkok
    Gallery:
    I got my bike back from its 24,000 km Desmo service. It took a ridiculous five days but I'm happy with the result. They changed oil, oil filter, air filter, brake pads, spark plugs, sprocket retainer shim, the chain, timing belts and did a valve clearance adjustment. I also had the Multistrada foot pegs fitted on recommendation of this forum. They're a little bigger and have rubber insets with more grip than the standard foot pegs - good mod, thanks. I think I may also have an updated map as the bike feels smoother at low revs. Price? It only cost me about 90 US$ (70 Pound) for the pegs and labor to have them fitted. I was lucky enough to get the Ducati Worry Free programme for 4 years or 30,000 km when I bought my bike so the service and parts were all done for freeee!
    The spark plugs and belts still looks good for 24,000 km use. What are the little metal half rounds? Are they from the valve shims?
  2. Dio_Brando
    Dio_Brando New Member
    Apr 1, 2017
    22
    1
    3
    Gallery:
    What was your total bill?
  3. trebor01
    trebor01 Active Member
    Jan 20, 2016
    139
    51
    28
    Hobart Tazmania
    Gallery:
    Good job Mine was 944$AUD fxxk Mostly labour as stuff hard to get to Doing it myself next time
  4. Phil McAvity
    Phil McAvity Member
    Sep 9, 2016
    31
    17
    8
    Bangkok
    Gallery:
    Free, except for the pegs.
  5. Plantboy
    Plantboy Active Member
    May 16, 2016
    110
    42
    28
    Roseberry Creek NSW Oz
    Gallery:
    Having my 12,000 km Desmo service in a couple of days. I believe the cost will be in the ballpark of AU$700+.
  6. Derek
    Derek Active Member
    Nov 20, 2014
    616
    217
    43
    NE Scotland
    Gallery:
    Yes. They are the half-rings that locate the closer shims to the valve stems. It is good practice to replace them at each Desmo service. They wear slightly and often simply replacing them brings the closing clearance back within spec. iI the closing clearances are left to get too large the resultant hammering can cause the half-rings to fracture and sometimes come out in 2 or more pieces.
    • Helpiest Helpiest x 1
  7. trebor01
    Jan 20, 2016
    139
    51
    28
    Hobart Tazmania
    Gallery:
    Shouldn't be that much only an oil change.Oil filter
    Aircleaner.Bout $270 mine was
  8. trebor01
    Jan 20, 2016
    139
    51
    28
    Hobart Tazmania
    Gallery:
    Oh and strangely or cause I ride like a girl..Brake pads 60% at front 80% at rear
  9. Derek
    Derek Active Member
    Nov 20, 2014
    616
    217
    43
    NE Scotland
    Gallery:
    The 12,000 km Desmo service includes;
    Change engine and oil filter
    Check and/or adjust valve clearance
    Clean air filter
    and a load of checks
    I'd expect it to be a bit more than $270AUS.
    • Agree Agree x 3
    • Like Like x 1
  10. Phil McAvity
    Phil McAvity Member
    Sep 9, 2016
    31
    17
    8
    Bangkok
    Gallery:
    Thanks Derek.
  11. trebor01
    Jan 20, 2016
    139
    51
    28
    Hobart Tazmania
    Gallery:
    Yep and all that should take no more than 11/2 hrs .Oil 80 $Filter 20$ don't use ducati one it leaks.Valves won't need checking till 24000 .But if they do check ..yep it'll cost ya
  12. trebor01
    Jan 20, 2016
    139
    51
    28
    Hobart Tazmania
    Gallery:
    Mmm you maybe right.Never did valves at 12000km check, .Lucky for me within spec at 24000km so still dosent need it
Verification:
Loading...
Draft saved Draft deleted
Share This Page
