Anyone see impact point under the fuel tank?
Discussion in 'Scrambler Talk' started by WalterT, Apr 15, 2017.
  1. WalterT
    WalterT New Member
    Apr 15, 2017
    12
    3
    Anchorage, Alaska
    Gallery:
    I have a 2015 and today the tank sprung a leak. I thought it was a loose hose, but to my surprise the tank had a pin hole were it impacted the frame? Both side under the tank were creased? See the picture. Anyone seen this? I'm puzzled how the frame member could touch the tank? Bike has never been down, and the tank has always been on the bike.
  2. Jackson
    Jackson Member
    Jan 14, 2017
    54
    7
    8
    Gallery:
    Is certainly odd, no explanation from me but it took something to make it happen
    If not warranty and I think they will say no
    I've fixed leaky tanks with both araldite and quick metal, think any two part epoxy would work
    One of these was my Africa tank, made night before crating bike to Mombassa in Kenya, filled there it pissed out, araldite got me to UK and is still holding 32 years later ! Araldite is forever. Clean paint etc off first
    Just make sure it can't rub again, spacers under mounts maybe ?
    I'll check ours to make sure it clears too, thanks
  3. WalterT
    WalterT New Member
    Apr 15, 2017
    12
    3
    Anchorage, Alaska
    Gallery:
    Your right some of this new two part puddly works great. I can't imagine what happens to cause the impact? After I have it welded or brazed, I'm warping the frame with rubber. Hate to be fire ball!
  4. Jackson
    Jackson Member
    Jan 14, 2017
    54
    7
    8
    Gallery:
    I don't advise warping the frame, but rubber prob wouldn't anyway, I think you should tell Ducati this has happened, if it is their assembly fault, they need to know sharpish, potential doesn't bear thinking about, I'm struggling with cause myself. Tanks bolted fore and aft
  5. greer
    greer Well-Known Member
    Oct 13, 2014
    1,074
    215
    63
    Glasgow, KY, USA
    Gallery:
    Walter,
    I'm with Jackson, do you mind to pass this along to your dealer? I've had my tank off but never paid attention to the underside. We've heard of leaks from the hoses and connectors, but I believe this is the first for a hole in the tank.
  6. Armo
    Armo Active Member
    Jun 6, 2015
    391
    125
    43
    Leeds West Yorkshire
    Gallery:
    Could it be a blocked breather pipe creating enough vacuum to suck the tank In?
    • Like Like x 1
  7. WalterT
    WalterT New Member
    Apr 15, 2017
    12
    3
    Anchorage, Alaska
    Gallery:
    Good point. I took it over to the guys at the local shop. They never seen anything like it, and checked the recall records. They are taking no action.
  8. WalterT
    WalterT New Member
    Apr 15, 2017
    12
    3
    Anchorage, Alaska
    Gallery:
    Do you really think the tank can have enough vacuum to implode a steel tank? I did remove the charcoal canister, and I did note a strong vacuum when I opened the tank last.
    After I get it welded, I'll check the breather pipe. Imploding at a leak point is the only possible thing, I can't see how the frame could have done it.
  9. Max Kool
    Max Kool Active Member
    Top Poster Of Month
    Nov 18, 2016
    439
    133
    43
    City of Angels
    Gallery:
    When you removed the charcoal canister, did you (accidentally?) block off the breather hose that ran from the tank to the canister by any chance?
  10. WalterT
    WalterT New Member
    Apr 15, 2017
    12
    3
    Anchorage, Alaska
    Gallery:
    Yes, I plugged the one that went to the canister and left the overflow open. I think your right, I hear rummers that DUCATI tried to use plastic tanks and found they broke off there mounts due to expansion and contraction. Guess that cap plays a big part in controlling the tank pressure. Expensive lesson learned.
    Thanks for the help on this!
  11. Max Kool
    Top Poster Of Month
    Nov 18, 2016
    439
    133
    43
    City of Angels
    Gallery:
    Wait what, you plugged the hose from the tank to the canister? And the canister overflow is open?
  12. Monstard
    Monstard New Member
    Nov 19, 2016
    11
    0
    1
    Gallery:
    That shoudn't happen. The only way i see it is that duca-thai installed a defective/lemon tank at the factory during assembly. Have it replaced under warranty. But first, undo what you did on the charcoal canister before you bring it to the shop. Otherwise, they might blame the mod as the cause just to avoid a warranty claim
    Sent from my SM-G935F using Tapatalk
Verification:
Loading...
Draft saved Draft deleted
Share This Page
