Ducabike Monoposto Rearset Subframe Kit (passenger pegs delete)
Discussion in 'Scrambler Gear & Accessories' started by Eshenbaugh, Sep 22, 2016.
  1. Eshenbaugh
    Eshenbaugh Member
    Jun 21, 2016
    74
    34
    18
    Arizona
    Gallery:
    Got these in from BellissiMoto - Exotic Parts for the Beautiful Italian in your life.
    Took two weeks to have them sent from Italy to NV then forwarded to me in AZ
    Very happy with the service from them.
    The Ducabike parts look great. Installation was very straight forward and ran into no problems. Fitting time was 2 beers.
    You will need a long 8mm hex key socket to remove the right side controls bracket and a 24mm socket.
    Other than that a set of metric hex keys and end wrenches will do it. Also don't forget your loctite.
    The controls are placed in the same location as stock.
    Weight savings was substantial.
    • Like Like x 5
  2. avonnieda
    avonnieda Member
    Aug 2, 2016
    31
    15
    8
    Edwardsville KS
    Gallery:
    Those things are sexy as hell, and they're in my future. Thanks for the great photos!
    • Like Like x 1
  3. vincelp
    vincelp Active Member
    Sep 1, 2015
    393
    109
    43
    Gallery:
    Hello
    What about the mounting points for the exhaust ?
    Are they located exactly in the same place ? With the same number of threaded points ?
    I'm interested in these parts, but I'd like to know if they fit with a Termignoni Evoline exhaust, with 2 mounting points on the right footpeg support.
    Did you order it directly in Bellisimi Moto site or in Ducabike site ? I can't find them on both sites...
  4. Eshenbaugh
    Eshenbaugh Member
    Jun 21, 2016
    74
    34
    18
    Arizona
    Gallery:
  5. vincelp
    Sep 1, 2015
    393
    109
    43
    Gallery:
    Thanks, but "stock mounting points" for which exhaust ?
    Because the standard one and the Termignoni Evoline have not exactly the same mounting points on the right side : 1 point for the standard, but 2 points for the Evoline.
    I've asked Ducabike the same question, I'll let you know when I'll get an answer.
  6. Petter
    Petter New Member
    Mar 17, 2015
    8
    3
    3
    Norway
    Gallery:
    Cool!
    Where did you get those extras on your side panel? Looks rad!
  7. Eshenbaugh
    Eshenbaugh Member
    Jun 21, 2016
    74
    34
    18
    Arizona
    Gallery:
  8. Petter
    Petter New Member
    Mar 17, 2015
    8
    3
    3
    Norway
    Gallery:
    Heyyy!
    Cool. Thank's!
  9. Kent
    Kent New Member
    Sep 19, 2016
    26
    4
    3
    Gallery:
    This looks like a really clean passenger foot peg elimination kit !! I have a flat track pro and I have the same question about the Termi Evoline slip on exhaust system which is standard on the FTP and full throttle). I have emailed back and forth with BellissiMoto and they said there should be no problem using the kit identified above with this exhaust. The didn't offer up any other details. Were you able to get any further info on this?
    Thanks,
    Kent
  10. Joooooooosh
    Joooooooosh Active Member
    Jul 29, 2015
    391
    76
    28
    Cheshire
    Gallery:
    From what I learned removing my FT Evoline Termi, it won't fit onto these rearsets, the same way as stock.
    There are 3 mounting points for the termi. Two on the right footpeg bracket and one bolt on the left, that supports the weigh of the cat.
    With these pegs, you're only going to be able to attach 2/3. The rearmost bolt on the right (a bugger to remove) that screws directly into the standard footpeg mount would have to be left out.
    I can't see that being a major problem though to be honest.
  11. vincelp
    Sep 1, 2015
    393
    109
    43
    Gallery:
    Hello
    I haven't got an answer from them, but I came to the same conclusion than you.
    I wouldn't say leaving 1 mounting point off has no consequences. If so, why would Termi and Ducati have put 2 mounting points on the right passenger peg ?
  12. Joooooooosh
    Jul 29, 2015
    391
    76
    28
    Cheshire
    Gallery:
    Most likely being over cautious as the stock setup is a bit heavy. You're perfectly within your rights to worry about it though.
    Excuse to get yourself a nice new exhaust...?
Verification:
Loading...
Draft saved Draft deleted
Share This Page
Search tags for this page
ducati monoposto subframe
