G2 Throttle Tamer.. .. .. Vs....2017 throttle tube ??
Discussion in 'Scrambler Talk' started by rhysbach, Apr 13, 2017.
  1. rhysbach
    rhysbach Member
    Mar 27, 2017
    36
    10
    8
    Gallery:
    Ducati fitted the G2 throttle tamer for me, but the throttle response is still very snatchy... low down
    It is fine from about 3000 rpm upwards and has a nice feel. Anything under that not good Best way I can describe it is light & slack no resistance on low down revs so extremely sensitive to touch. I kinda want it to behave more like an elastic band resisting the pulling action...
    Any other modes out there to correct this anyone had the 2017 throttle tube does it feel like this ?
  2. Jackson
    Jackson Member
    Jan 14, 2017
    54
    7
    8
    Gallery:
    Opposite for me, G2 tamer changed it completely, can ride walking pace over bumps now, impossible before. Corrugated dirt or slippery wet roads were really awkward, no longer. Did you get 600 cam (G2 recommended) ? Gives about half as much turn as orig
    Other than that, is it well run in ? If still new, maybe some miles on engine will do trick
    • Like Like x 1
  3. rhysbach
    rhysbach Member
    Mar 27, 2017
    36
    10
    8
    Gallery:
    The bike will go on its own at about 6 mph just extremely sensitive to touch..
    What is a 600 cam ?
    It has over 700 miles on the bike .
  4. Damnation
    Damnation Member
    Sep 3, 2015
    84
    28
    18
    Norway
    Gallery:
    I can't remember the number on mine but yes, it's still snatchy at low revs. I've learned to manage it with the clutch. The G2 helps a lot at slow speed though - I have much better control in roundabouts and the throttle is no longer on/off when maintaining 30-40 km/h.
  5. rhysbach
    rhysbach Member
    Mar 27, 2017
    36
    10
    8
    Gallery:
    Yea I dont get that, to gain control on roundabouts I often have to ride the clutch a little
  6. rhysbach
    rhysbach Member
    Mar 27, 2017
    36
    10
    8
    Gallery:
    Maintaining speed is good providing the gear is correct, and the revs are above 2500 - 3000 rpm
  7. pfmtrumpy
    pfmtrumpy Member
    Jan 23, 2016
    101
    21
    18
    Gallery:
    Yes you could ammend your riding style, which is fine and perfectly acceptable, to counter the overly lean fuel mapping. I've had race bikes on the road that required some "understanding "
    You could also employ a non linearity throttle cam if you wish.
    Since adoption of a "not for road use" mapping I can pretty much ride however I like and ride it as a motorcycle should be ridden. Your choice.
    • Like Like x 1
  8. vudiesel
    vudiesel New Member
    Oct 7, 2016
    20
    3
    Louisville, KY
    Gallery:
    I rode with the 2016 stock tube for about 400 miles. I fitted it with the G2. Made a huge difference but there is still some "snatch" to it, but not as bad as it was. Give it a little more clutch if you are doing slow maneuvers.
    • Like Like x 1
  9. Armo
    Armo Active Member
    Jun 6, 2015
    391
    125
    43
    Leeds West Yorkshire
    Gallery:
    Booster plug solved the snatchy throttle for me on my first scrambler but on my second one I've got the ducati race ecu and termignoni which also tames the throttle.
    • Like Like x 1
  10. Damnation
    Damnation Member
    Sep 3, 2015
    84
    28
    18
    Norway
    Gallery:
    I got the Rexxer map and can't say I've noticed an effect at low revs. Then again the bike has been in the garage for more than 4 months, my memory might be playing tricks on me.
    At full throttle though - wow! What a difference a few bytes can make.
  11. Armo
    Armo Active Member
    Jun 6, 2015
    391
    125
    43
    Gallery:
    Yeah Defo has more juice at the top end with the zorst and ecu chip, the throttle felt slightly softer as struggled 2 up before I got the booster plug unless I got used to the snatchy nature, the wife also stopped head butting me!
    • Like Like x 1
  12. rhysbach
    rhysbach Member
    Mar 27, 2017
    36
    10
    8
    Gallery:
    I'll give the bosster plug a try also gonna order the 2017 throttle tube to see of that makes a difference. .
Verification:
Loading...
Draft saved Draft deleted
Share This Page
Search tags for this page
ducati scrambler 2017 trottle tube
