I'm feeling pretty dumb...tried taking off side panels
Discussion in 'Scrambler Talk' started by Dio_Brando, Jun 17, 2017.
  1. Dio_Brando
    Dio_Brando New Member
    Apr 1, 2017
    22
    1
    3
    Gallery:
    And I ended up stripping the hole for removing the side panel under the decal.
    Is there a secret way to removing it? Or should I just have my dealership remove and replace since I need new tires anyway?
    Help
  2. Max Kool
    Max Kool Active Member
    Top Poster Of Month
    Nov 18, 2016
    522
    148
    43
    City of Angels
    Gallery:
    Sure you stripped the hole, and not the bolt?
    (You can always JB weld something back)
  3. Dio_Brando
    Apr 1, 2017
    22
    1
    3
    Gallery:
    Yeah it's the hole where the Allen key goes in
    To clarify, it's the hole of the screw that holds the panel together.
  4. dkaplun
    dkaplun Active Member
    Aug 31, 2015
    106
    39
    28
    Gallery:
    You are NOT alone. Some jackass ended up putting red loctite at the factory on the left side panel and i had to drill it out last year (curiously the right panel had no loctite and came out just fine). This isn't a bug, it is a feature.
    Next time use the dealer...and I say that because I ended up heating the left side, using the hair dryer, the works...and it did nothing. Very frustrating.
  5. Max Kool
    Top Poster Of Month
    Nov 18, 2016
    522
    148
    43
    City of Angels
    Gallery:
  6. pastorwug
    pastorwug Member
    Jun 23, 2016
    76
    11
    8
    Gallery:
    I've heard that you can, but it won't stand regular tightening.
  7. ash73
    ash73 Member
    Sep 30, 2015
    38
    8
    8
    Chester, UK
    Gallery:
    Next time you're struggling with loctite just touch the bolt with a soldering iron for a few seconds it will heat up and melt the glue.
    • Helpiest Helpiest x 1
  8. GodDangItBobby!
    GodDangItBobby! New Member
    Nov 7, 2016
    6
    3
    Gallery:
    I did the same thing, rounded off the allen hole in the bolt head. I ended up getting help removing it using a screw extractor and then filed a slot in the bolt head effectively making it a flathead bolt for future use. There was red loctite on the threads as others have mentioned. Why?!?! Anyways you can probably get it out using a screw extractor and being very very careful.
Verification:
Loading...
Draft saved Draft deleted
Share This Page
