Starting problem
Discussion in 'Scrambler Common Problems/Issues' started by HarveyL, Jul 6, 2015.
  1. HarveyL
    HarveyL New Member
    Jul 4, 2015
    3
    0
    1
    Virginia, USA
    Gallery:
    I have experienced a problem with starting on two occasions in three weeks. The first a couple weeks ago. Following a 200+ mile trip with several stops the bike sat for a few hours and then refused to start. The starter turned over and the engine said puff / puff. I turned it over maybe a dozen attempts in first gear, in neutral, clutch in, clutch out, kickstand up, down. Checked voltage, no problem. The bike sat over night and refused to start in the morning. I made arrangements for transport in the morning. While packing up, I gave it a last try and it coughed and started. Drove home, 200+ miles with stops for food and gas, no issues. Reported the problem at my 600 mile service. The bike had recorded no problem code and was running fine. This week on starting, in the garage while cold, it made a POP and refused to start. Sounded the same it turned over and puff / puff. After a half dozen attempts, this time it started. Has anyone else experienced a similar issue?
  2. greer
    greer Well-Known Member
    Oct 13, 2014
    1,030
    202
    63
    Glasgow, KY, USA
    Gallery:
    Hello Harvey, welcome to the forum. I don't have a Scrambler yet, but trying to learn all I can. Did you give any throttle during any of your attempts to start? I owned an EFI bike some years back and they were known to do this same thing on occasion, the given advice was to hold the throttle wide open while cranking, sure enough that worked every time. I am not suggesting you do this, just sharing past experience. We'll look forward to some Scrambler owners chiming in.
  3. Hui
    Hui Well-Known Member
    Jan 11, 2015
    827
    369
    63
    No longer a member
    Gallery:
    Opening the throttle like that allows a large volume of air into the engine and can help to purge an engine of 'flooded' fuel. Unless of course it's fly by wire, nothing opens as throttle bodies are not actioned by the twist grip.
    This method works best on carburatored engines and strongly not advised with catalytic convertors. 1) because the raw fuel can damage the precious metals in the cat and 2) the cat is/can be the hottest part of an exhaust, up-to 600 C and could damage the exhaust if the backfire is big enough.
    Just some pub trivia for you. Plus I'm bored.
    • Agree Agree x 1
  4. tonyjuliano
    tonyjuliano Active Member
    Jun 16, 2015
    613
    215
    43
    Philly, USA
    Gallery:
    You may be bored, but you are certainly correct in every way.
    • Agree Agree x 1
  5. SuperKörny71
    SuperKörny71 Member
    Oct 31, 2014
    66
    54
    18
    Gallery:
    Any explosion is good.
    Warning. May lead to new full race exhaust.
    • Funny Funny x 1
  6. Kiwipete
    Kiwipete Member
    Jun 20, 2015
    50
    11
    8
    Gallery:
    I had a similar problem when i first got my Classic. But that was because i would turn the throttle as on carby bikes. now i just push the button and let the electronics manage the fuel and start. .
    Sent from my SM-G900I using Tapatalk
    • Agree Agree x 1
  7. Piero
    Piero Member
    Apr 3, 2015
    58
    70
    18
    Gallery:
    Do you shut down by turning the key off or by using the emergency switch ? A guy on another forum had same issue and it showed that using the emergency switch to shut down is not the proper method. It closes electrical circuits in a way that the ECU has difficulties to start over again.
  8. ELVISTO
    ELVISTO Moderator Staff Member
    Feb 5, 2015
    2,611
    794
    113
    Audley, Staffordshire, UK
    Gallery:
    Think I've only used the emergency cut out a couple of times, I just use the key,
  9. John
    John Active Member
    Apr 22, 2015
    129
    28
    28
    Warrington UK
    Gallery:
    I always use the switch next to the throttle to switch the bike off, never the key, is this wrong? If it is why is it?
  10. DaveInWoodland
    DaveInWoodland Active Member
    Oct 11, 2014
    965
    235
    43
    Northern California
    Gallery:
    Some people have reported that the ugly evaporative canister has caused some start up issues, so far I have been lucky as a California owner I cannot remove mine but that doesn't apply to everyone else. Also was told that over filling the gas tank can cause this as well.
  11. HarveyL
    HarveyL New Member
    Jul 4, 2015
    3
    0
    1
    Virginia, USA
    Gallery:
    I have used the kickstand switch to stop the engine. I can't remember if I did when this problem has occurred. I have not had a reoccurrence in the last few weeks. I will make a point to use the switch on the handle bar and see if it happens again. Thanks for the tip.
  12. lediamantbleu
    lediamantbleu New Member
    Aug 26, 2016
    19
    4
    3
    Germany
    Gallery:
    Hi,
    What was the outcome of this? My Urban Enduro is having issues of the start/neutral persuasion.
Verification:
Loading...
Draft saved Draft deleted
Share This Page
Search tags for this page
djebel 250 scrambler starting problems in morning
ducati scrambler cold start
ducati scrambler fuelling problem
ducati scrambler probleme
ducati scrambler problems
how to troubleshoot ducati 350 scrambler failure to start
ignition problem on my triumph tr6
problem ducati scrambler
problems with 2015 ducati scrambler
scrambler ducati cold running issue
