Valve adjustment
Discussion in 'Scrambler How-To's and Guides' started by greer, Jul 11, 2016.
  1. greer
    greer Well-Known Member
    Oct 13, 2014
    1,056
    207
    63
    Glasgow, KY, USA
    Gallery:
    Any of you plan to adjust your own valves?
  2. nuttynick
    nuttynick Well-Known Member
    Feb 10, 2015
    589
    285
    63
    Kent UK
    Gallery:
    Nope, they're a real bugger to get to on the Scrambler, it's very compact! Plus I don't have a big box of shims and can't be arsed to get them posted ;-) I've rebuilt motors before where I've dropped the heads in to a local indie to be reshimmed. Earlier heads need a factory tool, not sure about these though.
  3. Derek
    Derek Active Member
    Nov 20, 2014
    590
    207
    43
    NE Scotland
    Gallery:
    I'll be doing mine. I've done the valves on loads of Ducatis before, both 2V and 4V, and don't see it as a problem.
  4. greer
    Oct 13, 2014
    1,056
    207
    63
    Glasgow, KY, USA
    Gallery:
    That's good to hear, Derek. We've generally tended to the valves on other bikes, some with shims, but mostly screw and lock nut. I hope to tackle this, but have to say I'm spooked. Are these particular shims Ducati only? I figure so. Thanks again.
  5. Derek
    Derek Active Member
    Nov 20, 2014
    590
    207
    43
    NE Scotland
    Gallery:
    It's not a difficult process Sarah. The shims are indeed Ducati specific. The openers are easy to access and change, the closers much less so, but if you are patient and take your time to understand how the system works most average mechanics should have little difficulty. Always measure 3 times to be sure you don't get a spurious reading.
  6. Derek
    Derek Active Member
    Nov 20, 2014
    590
    207
    43
    NE Scotland
    Gallery:
  7. nuttynick
    Feb 10, 2015
    589
    285
    63
    Kent UK
    Gallery:
    Talking to the guy that did mine, the main pain is access :)
  8. Derek
    Derek Active Member
    Nov 20, 2014
    590
    207
    43
    NE Scotland
    Gallery:
    That's where patience is required :)
  9. Eshenbaugh
    Eshenbaugh Member
    Jun 21, 2016
    75
    34
    18
    Arizona
    Gallery:
    I plan on doing all of my own maintenance.
    Read up and take your time and its not rocket science.
  10. nuttynick
    Feb 10, 2015
    589
    285
    63
    Kent UK
    Gallery:
    It may be worth buying a replacement fuel line clip just in case ;-)
  11. vincelp
    vincelp Active Member
    Sep 1, 2015
    406
    111
    43
    Gallery:
    Hello
    Or cut the fuel lines for the first dismount and install quick connectors on both hoses for future dismount.
    • Like Like x 1
  12. greer
    Oct 13, 2014
    1,056
    207
    63
    Glasgow, KY, USA
    Gallery:
    Thanks, thanks, everybody. I've got the fuel line disconnect tool from Motowheels on the way, there's step one. Thanks for the guide Derek, I'll start studying. More questions to come, for sure. First off, we've always found TDC by bumping the rear wheel, that OK for this bike, I reckon? Thanks again.
Share This Page
Search tags for this page
how to adjust valves on 800 scrambler
is the ducati scrambler 2 valve or 4 valve
vavle adjustment on a ducati scrambler
