What Chain Cleaner and Chain Lube to use?
Discussion in 'Scrambler Talk' started by Hawkeye, May 8, 2017.
  1. Hawkeye
    Hawkeye Member
    Apr 19, 2017
    61
    10
    8
    Maryland, USA
    Gallery:
    Hi everyone:
    So my Scrambler is my first chain driven bike. I've owned a BMW for the past 14 years so I know shaft drive maintenance, but not chain drive. I know I've got to clean and lube the chain, and I've got a pretty good idea of how often and generally how to do it, but I have no idea what products are good and which ones are crap snake oil.
    So, any advice? What do you all use for cleaning and lubing the chain? What's a good lube that won't fling off all over the place?
  2. hamer
    hamer Member
    Oct 7, 2015
    34
    6
    8
    Huntington Beach, CA
    Gallery:
    I've had the best luck with Chain Wax
    • Agree Agree x 1
  3. jazzndre
    jazzndre New Member
    Apr 25, 2016
    5
    4
    3
    Gallery:
    The best lube tested by me so far is JMC Kettenspray "Topsynth". The best cleaner: JMC KETTEN REINIGER. I also used various Motul lubes (each one either too greasy, too tar-like) and Yamalube Chain Cleaner (cleaning gel, must be water rinsed after use).
  4. Joooooooosh
    Joooooooosh Active Member
    Jul 29, 2015
    426
    81
    28
    Cheshire
    Gallery:
    I just use small amounts of WD40 to clean the chain and Castrol dry 'Racing Lube' and my chain has remained nice and healthy.
    I've used various different combo's before and this seems to work the best.
    I try to clean and lube every 350-400 miles now I don't ride in bad weather. When I was commuting in winter, it was every weekend.
    Got lazy with the Scrambler chain and ruined it. So I've got a nice shiny DID gold link one on now. It's given me a bigger incentive to look after it.
  5. vincelp
    vincelp Active Member
    Sep 1, 2015
    420
    116
    43
    Gallery:
    Hello
    Best solution : a Tutoro Oiler.
    Your chain is permanently oiled, no need to clean it and it lasts longer.
    • Like Like x 1
  6. Joooooooosh
    Jul 29, 2015
    426
    81
    28
    Cheshire
    Gallery:
    Surely you'd still need to clean it periodically? Dirt and grime is what really kills them.
  7. Deano968
    Deano968 Active Member
    Nov 4, 2015
    337
    86
    28
    Sydney, Aus
    Gallery:
    I've got one of those 3 sided brushes that you can slot around the chain links after soaking it in WD or paraffin - works a treat.
    I use chain wax which I haven't had an issue with but I would advise you try not to spray it on anything but the chain. It won't do any harm but I did a 'really good job' of cleaning my chain a good while ago then had to spend another hour cleaning the wax of the back wheel. Once it sets it's a bit of a bugger :oops:
    One of these...
    • Like Like x 2
  8. Max Kool
    Max Kool Active Member
    Top Poster Of Month
    Nov 18, 2016
    522
    148
    43
    City of Angels
    Gallery:
    I had the same with grease flinging off a brand new EK chain.
    Sticks to the tire really good (too good)
  9. Hui
    Hui Well-Known Member
    Jan 11, 2015
    946
    421
    63
    No longer a member
    Gallery:
    I've used Scot-oiler for years and think they're fantastic especially as they have a small bottle available now too.
    Next time round I'm going to try the Tutoro Oiler as they don't even need a vacuum fitted.
    I suppose any of this type of product is the best for the chain, and no mess on the wheel/tyre when set correctly.
  10. Deano968
    Nov 4, 2015
    337
    86
    28
    Sydney, Aus
    Gallery:
    I thought oilers were only really recommended for old 'unsealed' chains?
  11. Max Kool
    Top Poster Of Month
    Nov 18, 2016
    522
    148
    43
    City of Angels
    Gallery:
    No, they work wonders on O ring chains (too). Besides, when was the last time you saw a motorcycle with a non O ring chain?
  12. Deano968
    Nov 4, 2015
    337
    86
    28
    Sydney, Aus
    Gallery:
    Mmmmmm, probably giving my age away a bit too much there ;)
Verification:
Loading...
Draft saved Draft deleted
Share This Page
Search tags for this page
scrambler chain cleaner
