bevel. So I have no idea what you have done.[/QUOTE]This a picture (not a very good one) of the bevel gears at the cylinder head.
The tacho drive is mounted in the outer cover (not shown) and engages with the slot on the end of the camshaft. The bevels on the camshaft and vertical shaft have timing dots on them. You can see the dot on the vertical shaft bevel in the picture. The timing is correct when the dots on both are lined up and the engine is at TDC with both valves closed at the end of the compression stroke.
You can also download a manual off the Bevelheaven site. It sounds like you could use one.![]()
Sorry bout that,it is the tach and the bevel gear,not the speed cable. After the cable came out ,I took the cover off and saw that that gear was damaged.........so I tried to start the engine ( serial # 09941)* without that small gear and thats when I noticed I had lost some compression......so I thought now the timing must have changed ,like the valves not closing correctly.
Not sure exactly why I had it running great one minute and not at all the next.
Thanks for your help... I think that's exactly the place I need to check.....how do I put the timing back correctly?
Thanks again
Al
Hi I just checked....found both timing marks on both gears....put piston at TDC and they DO NOT MATCH UP!......where should I correct this?, with the TOP GEAR THAT HAS A HOLDING NUT ON IT?
