There is yellow outline on the wheels too,Wow, that's weak...
Slap on a plastic number plate and I guess you're a "pro".
You're right... PRO!! :02.47-tranquillity:There is yellow outline on the wheels too,
Wow, that's weak...
I had the same impression as you - with just the seat, the back end looks unfinished. I like the FTP number plates because they fill in a lot of "open space" which also looks unfinished on the other models. If you haven't picked a tidy tail yet, I would highly recommend Storz. It's very high quality, properly designed and easy to install. I originally had an R&G but the bend angle is incorrect and on the first ride it caught the tire and folded under.Wow Kent, that looks awesome! Now I want my bike to look like yours. After I removed the large plate arm I was thinking the back end looked a little unfinished & seeing your fender mod confirmed it. Are you considering a seat? I like the look of the stocker better than aftermarket ones, but after ~20-30 miles it's not comfy, not the worst, but needs improvement. Thanks again for the pics & info!
