1 - 20 of 43 Posts
· Premium Member
Price better be very competitive...
They "cheaped-out" on the swing arm, front brakes & forks (not that the forks on the 800 are anything to write home about).
Should have been lighter, too
Guys. The price came out. 7,990 € for a 400 twin. Are you for REAL? Why would anyone buy this over the 8,590 € icon? or even better the 6,199 € Yamaha MT07 700cc twin?
Specs from a French website translated to English with google:
Engine: L-twin, air-cooled, Desmodromic timing, 2 valves per cylinder
Capacity: 399 cm3
Bore x stroke: 72 x 49 mm
Compression ratio: 10.7: 1
Power: 41 hp at 8,750 rev / min
Torque: 34.6 Nm at 8,000 rev / min
Supply: electronic fuel injection, 50 mm throttle bodies
Clutch: multi-disc oil bath
Transmission: 6-speed
Final Drive: Chain, 15/48
Setting: tubular steel trellis
Front Suspension: Showa 41 mm telescopic fork, 150 mm travel
Rear Suspension: Kayaba monoshock absorber adjustable in preload, 150mm travel
Front brake: 320 mm disc, 2-piston floating caliper, ABS
Rear brake: 245 mm disc, single piston floating caliper, ABS
Wheels: Rims 10-spoke light-alloy
Front tire: 110/80 R18 Pirelli MT60 RS
Rear tires: 160/60 R17 Pirelli MT60 RS
Wheelbase: 1,460 mm
Caster angle: 24 °
Trail: 112 mm
Length: 2150 mm
Width: 860 mm
Height: 1165 mm
Seat height: 790 mm
Tank 14 liters
Weight fully fueled: 183 kg Availability / Price
Colors: gray, black, orange
Availability: 2016
Price: € 7,990
· Premium Member
Price is a total fail....
· Premium Member
Got to pay for the fancy teaser videos.
Apparently...
Ducati may have hit a home run with the 2015 800's - but they have fallen on their collective faces with the "Flat Track Pro" and the 400,
Reactions: DaveK
From another site I reviewed the same basic thread and even with the Asian market nuances I can't see the 400 being very well received. I really think they didn't think this one out much. For sure it won't be successful in the US market. Just doesn't make sense price wise.
That price is only £580 cheaper than the Icon when it first came out - you'd probably be able to get a good as new s/h 800 for less than that. Be interesting to see if the order books are as busy as they were earlier this year!
my guess at that price they will still sell a lot to consumers that think an 800 cc bike is too "big" For them. Then those people will soon be riding another ducati. Our bike at least for now Probably was not the BIG money maker. The money will be made in the 400 and in the pro model. At least my thoughts, which are based on no fact just opinions.
1 - 20 of 43 Posts
