1 - 8 of 8 Posts
I am noticing that my clutch is slipping at higher speeds / higher loads..
I am still under warranty but the countless threads I have read is 50/50 that they will replace.
I have 13k miles on it.. I use it to commute.. never seen dirt.. got the break-in and valve check done by dealership....
the only thing I have done was new chain and new sprockets (stock)...
What clutch are you guys using when replacing the stock clutch?
TIA
I fitted a Barnett but only about 500km ago - all is (obviously) well so far. Recently had the bikeshop check the free play for piece of mind. Hopefully I'll hit better figures than the ~11500km I got from the Ducati one. As said above the freeplay is crucial.
I don't think so for a Desert Sled.
I took my Sled clutch apart and went to Barnett as they are just around the corner from me. The Sleds have a different clutch than the other Scramblers, it's the same as the clutch in the Monster 821.
It is a grip/slip type clutch where as the other Scramblers have a "normal" clutch.
Here's some photos for reference.
And the parts diagram for a Monster 821. I have actually purchased the "pack kit" ie steel and friction plates for the 821 and can confirm they fit. The only difference is the 821 uses 1 thicker steel plate.
1 - 8 of 8 Posts
