1 - 4 of 4 Posts
Hey guys,
I have a 2019 Icon and the frame or exhaust is slightly different than previous years because the heat shield goes over the hole on the frame for engine guards and frame sliders.
How have others addressed this? Is there a compatible product or do I need to modify the heat shield?
Thanks
Did you have to remove any main bolts or brace the engine when installing?
Very easy to install, you only need a jack to support and wiggle the engine a bit so you can slide out the engine mount bolt with the frame slider bolt.
Takes about 5 minutes.
1 - 4 of 4 Posts
