Update: New handlebars, risers and instrument holder
So it's been a long time since updates! As a bit of a refresher, I'd bought a
Rizoma handlebar MA009B and a simple set of
risers/handlebar mounts. I'd also bought
this instrument holder, but it ended up getting stuck in Germany - so I had to wait until a mate could bring it back with him to Australia (complete with two weeks in quarantine).
Now I hadn't come across this handlebar being installed on a Scrambler before, but I liked the width, did some rough calculations to see if it'd hold the controls, and it seemed good to me. I though it was similar to the Full Throttle bar, but it's actually a fair bit narrower.
Installation
Installation wasn't particularly hard, and I definitely have more confidence these days anyway. The main challenge with installing the bar is that there's a set of guiding holes in the bar to align the controls on the left, and the controls and throttle on the right (two). So these need to be drilled into the new bar. There are also some dimples at the top of the bar, but these are for alignment only.
Disassembly was pretty simple. Everything is hex keys, except the bolt holding the the handlebar mount - this is a 15mm bolt/nut combo.
To get the holes in the right spot, I loosely installed the new bar, found the optical 'top' of the bar, and then copied the measurements from the OEM bar. These measurements were mm from the end of the bar, then rotation from the 'top'. The bar was tough to drill through, but I had a couple of nice tools to help: the V-Drill guide I got off Amazon, and a clamp to help hold it (although that wasn't enough, I had to hold it as well). I taped the bar up to mark the measurements and to minimise scratching.
I ended up fucking up once - I rotated the wrong side for the clutch hole, so had to drill a second hole there. Overall pretty happy though. The levers are just where I want them, however the left controls (indicators/horn) are a bit low. Totally manageable, I just have to stretch my thumb a little to reach them.
As you can see in the photos, the reservoirs are a lot closer to the middle of the bike now. So much so that the brake sits over the instrument panel a bit. It doesn't cover important info, but still contemplating if I should get a different solution there. Aftermarket options like the Brembo master cylinders are super expensive (and overkill for what I'm trying to achieve), so I might see how much the Cafe Racer reservoir is from my Dealership at my next service.
I also got around to adding the aluminium trim for the instrument panel a couple of days later. While I got this like half price, its still probably the most overpriced part on the bike. Note to install, it required a T6 Torx.
Performance
To an observer, my posture hasn't changed much, but it definitely has a different feel. Much sportier. By default I now lean slightly forward rather than directly upright, but the main difference is the width. I've never ridden a bike with clipons, and assume that's much more dramatic, but the bike feels a lot more responsive when I want to turn. I'm still getting used to it at super slow speeds and when I'm going slow with a pillion, but I definitely like the change. It looks far superior too!
What's left?
Two main things are remaining: the seat (and accompanying side panels) and the exhaust. I ordered a Mugello seat way back in June/July, and they've been absolutely terrible to deal with. Despite numerous promises of it being finished by X date, or I'll receive a tracking code by Y date, I've seen nothing. I've given them one last chance (48 hours) to supply a tracking code, otherwise I'm cancelling the order through PayPal. I don't think I've had a worse experience with buying something before. If it comes to that, what other seats do people recommend?
The exhaust is getting installed by the dealer at my next service, which I think will be as soon as a week or two away. So at least that's good news!
