I was told the new speedo would take the programming from the bikeUsually the dealer would program the key to the gauge unless you know who can do it for you. Ive had to replace locks because I bought DS that was stolen at some point and I sent my dash out to Rexxer to have they keys programmed to the chip inside the dash.
You were told wrong. You need a dealer to program the speedo properly.I was told the new speedo would take the programming from the bike
How did you take your old speedo apart? I removed the 6 small hex screws from the back?...My LCD is completely destroyed and would consider replacement if possible or find a replacement and remove the board as you did...just need help on separating the speedo to get to the internals.i transferred the board from the old speedo that only had a cracked screen
nopeI removed all of the small screws from around the bezel and the halves won't come apart...just wondering if you had a tough time or if the halves were easy to separate. I have an LCD screen that's damaged but need to get to the internals so I can keep the original odometer reading.
