Picked up a used '18 Desert Sled with only 300 miles a couple months ago for a sausage party trip to Moab, Zion, Durango, and the areas around it all. I'm usually a vintage rider. Looked into a couple adventure bikes - KTM 890, Triumph Tiger, and a couple touring bikes. The more I looked at them, I kept coming back to style - usually a terrible way to choose a bike for traveling. But, I have to say, I was pleasantly surprised by the sled. We went just over 3000 miles in about 9 days. The roads and routes we took were spectacular. The bike performed flawlessly.
Since we were going to do a lot of miles at 60-80mpg, I changed the front sprocket to a 16T from the stock 15T. That helped a bit with the top end, but still rev'd close to 6000 rpms when doing 75-80mph. It also took away more of the low end grunt than I thought it would. Wasn't too bad when I figured out it likes to be in the 4-6k rev range. The engine was smoother at 6k than it was at 4k. I was a little worried at first, but now, after the trip is done, the motor is broken in and much tighter.
I also put on a Puig windscreen in hopes I'd shove some of the wind around my 6'3 frame. It was more of a suggestion than reality. Not sure if it made the wind noise louder or not. It did seem to take a little wind off the chest. Not much though.
For luggage, I have a Hepko & Becker rear rack fitted with a moto-pax 1 gallon fuel can, some Wolfman 12L saddlebags for tools and daily stuff, tank bag, and a 50L dry bag.
I probably had too much - but, you never know.
For road riding and canyon carving, I was blown away with how well the Pirelli Scorpion rally tires did. No buzzy rumble like knobbies. Smooth and quiet. They were good on the limited gravel we found ourselves on from time to time. I'll probably go with them again when it's time to change them out.
The seating position is very comfortable for me. The actual seat got a little uncomfortable on the long days - but I just stand up from time to time. Everyone else in the group was standing as well. I don't know if there is a genuinely comfortable seat (outside of a Goldwing or Road King)
Cruising on the bike 65-80mph was very smooth. Passing took a little looking ahead, but once I figured out what the bike would do, it was fine. Definitely not as powerful as my Hypermotard 1100S. But - I'm about 235 all geared up, and had about 50lbs of gear and tools that was loaded on there as well.
When canyon carving, I found the handling great for my style of riding. (not sure what it is) I could lean/turn it very well. I was easily keeping up with all the other bikes through corners. My only complaint was coming out of corners. Was wanting more torque. Brakes were fine - never noticed the ABS.
I was consistently getting 50 miles per gallon. The fuel light came on between 125-130 miles. So - reserve was about a gallon. Only had to use my RotoPax once.
So, my fuel range was easily 150 miles and more.
Now, what will I change?
Need to look into tuning the suspension. It felt pretty darn good to me (not an expert) but, I'm sure it wasn't designed for geared up Clydesdales (230lb)
I never bottomed out that I felt. Looked to be within a couple millimeters on both the front and rear. Not sure what I will do there - need someone more knowledgeable than me. Maybe just a heavier spring on the back and in the front ?
I would also like a little more power. Just now starting to look into removing the CAT and getting a slip-on, different intake (filters or more?) and an ECU flash/tune to go with the exhaust/intake. Much of the reading I've been doing, doesn't seem to be recent. What are you guys doing along those lines?
