1 - 15 of 15 Posts
i don’t want to get things wrong again so I will ask the question first. Are the 800 and 1100 headlights the same? I ask as I’m fancying the aluminium headlight ring either OEM or Ducabike. What do you think.
This is what I think...
Skippy which ring is that OEM?
Yep that's the OEM one. My 800 already came with it and using the Ducati Scrambler 1100 online configurator I was able to figure out wich items I could use from the 800 on the 1100. The configurator also shows the item numbers so you can compare them.
If you look on that website it has all the part numbers for the 1100 and the 800. Should be all the info you need.
Very usefull site! Thanks!
I looked up what the original end cans cost and just couldn't believe it, £ 936 for the left and another £936 for the right one and that's without the heat shields and other parts[wideyed]
Makes the Akrapovics look like a bargain!
1 - 15 of 15 Posts
