So my FT was due for its first oil change, given its now 600miles old. So anyway, cos its a Ducati, and well Italian bikes are just that little more temperamental, I decided to do everything textbook, and by that, i mean, buying the proper oil that the dealer uses, buying a new crush washer, even set my torque wrench to 32ft lb to tighten the oil drain bolt, instead of my usual hand tight and 1/4 turn. BUT !!!!!!!! things didn't go according to plan.
My drain bolt felt like it wasn't tightening according to spec. Even double checked myself with a 2nd torque wrench, cos you know that feeling, when you say to yourself, surely it should of clicked by now... So i even grabbed a 2nd 1/2" torque wrench along with an adapter, that was correctly set as i had just used to tighten the big 14mm hex bolt, and the inner gauze thingy to 32ft lb.
Anyway, goddam bolt just fell apart on me, like as if it was made of cheese. Of course not before i turned it in too much and stripped some of the thread of the casing.
TBH, i think i'm probably OK. And really i could even run down to Autozone and pick up a replacement 12mm 1.50 pitch drain bolt, but it probably won't sit flush, so i'm still going to do it properly and get the proper Ducati one, even though it literally fell apart on me, with very little force don't forget. 32ft lb, isn't a whole lot of torque !!!
It can only mean one thing.. The metal they used is crap ! Just being honest. My bike was built in Taiwan, and now I'm getting nervous about the rest of the components. I hope to dear god, that this was a one off, and that this bike isn't going to be plaqued by poor quality. This really should NOT of happened on a 600mile bike.
and just to show you, i'm not crazy, 42nm is 32ft lb thereabouts..... Just as i had everything set !!!
