Retikulum thanks for the compliment...
for the tail light I've chopped parts of the rear frame to make it shorter then installed the frame loop and the LED taillights
the front fork kit came from andreani. it is a full kit, completely plug n play. it comes with the triple clamp, brake caliper brackets and fender mounts.. the triple clamp needs to be changed to accommodate the smaller diameter of the forks.. OEM forks = 51mm Ohlins forks =43mm.
Its a night and day difference switching from the OEM forks to the ohlins... this is my impression from the few kms I've tried it
the seat pan is custom made to fit the new dimensions of the chopped rear end. you cannot buy it elsewhere since its measured to fit my bike
(not unless somebody copies it and sell it commercially)
the wheels are OEM scrambler classic spoke wheels, i just change the sprocket and chains to aftermarket ones..
cheers:adoration:
