Hi everyone,
I've been adjusting my aftermarket clutch lever today when I noticed something.
With the lever adjusted to be nearer the handlebars ie number 2 on the settings, there is less force returning the lever back to its original position compared to when the lever adjustment setting is further away from the handlebars ie number 5 or number 6.
This got me thinking.. I wondered if this change in lever return pressure would affect the distance travelled by the clutch arm.
It looks like the clutch arm moves between 3 or 4mm less when the clutch lever is adjusted nearer to the handlebars.
My question is this, does the clutch arm have to travel the maximum amount of travel available to fully disengage the clutch?
Thanks.
Thanks.
