That's not the question, innit?layful:
How, that's the question.
(some people dream of fitting different sized wheels, which screws up the ABS apparently)
Apparently the bike will run/ride fine without it, but the speedometer gets the signal from rear ABS sensor, so you will not have speedo/odo/trip.hi, did you remove the abs in the end? I’m about to take mine off. Just wanted to ask if there was any issue with the computer after it was removed.
I’ve removed the whole unit, pump, hoses, sensors, phonic wheel, the lot. You get an error flashing on the dash but i’m ok with it as the bike is race only & don’t even run a front brake. Easy enough to do and saves you some weight.hi, did you remove the abs in the end? I’m about to take mine off. Just wanted to ask if there was any issue with the computer after it was removed.
Hello, Most of us experienced riders detest ABS, Could you possibly provide part numbers for non-abs replacement brake line? ThanksI’ve removed the whole unit, pump, hoses, sensors, phonic wheel, the lot. You get an error flashing on the dash but i’m ok with it as the bike is race only & don’t even run a front brake. Easy enough to do and saves you some weight.
That is incredible general and simply not true. IMO ABS is the single best safety addition to motorcycles in the 51 years that it have owned and ridden them.Hello, Most of us experienced riders detest ABS,
Hi, unfortunately I can’t provide a part nr. as I make my own brake lines. I can’t even replicate them as I use a completely different set up with a PS13 rear master cylinder and a P34 calliper. Beside is not as simple as you’ll have to blank out the ABS pump both ways for the rear. You could of course disconnect altogether like I did, with the small inconvenience of a dash light. All in all, unless you’re doing it for either racing or weight saving, is a lot of trouble to go to, especially at the rear. But I can of course help, if you’re in London hit me up.Hello, Most of us experienced riders detest ABS, Could you possibly provide part numbers for non-abs replacement brake line? Thanks
Advantages are marginal at the front and definitely not needed at the rear. Not saying that is not a positive to have it but there have been bigger advancements in safety in a number of areas that are way more beneficial.That is incredible general and simply not true. IMO ABS is the single best safety addition to motorcycles in the 51 years that it have owned and ridden them.
Yet another qualitative statement with no reference to context or audience. Even the crappy Honda Grom ABS deserves a contextual reference before generalizing it as a marginal advantage.Advantages are marginal at the front and definitely not needed at the rear. Not saying that is not a positive to have it but there have been bigger advancements in safety in a number of areas that are way more beneficial.
Agree. If people don’t want to use ABS s expire it’s factually proven advantages for road riding that is their choice but they should not be saying that they are in the majority because they are not.Yet another qualitative statement with no reference to context or audience. Even the crappy Honda Grom ABS deserves a contextual reference before generalizing it as a marginal advantage.![]()
Or just someone else’s opinion and as such should be respected.Yet another qualitative statement with no reference to context or audience. Even the crappy Honda Grom ABS deserves a contextual reference before generalizing it as a marginal advantage.![]()
Never said I was in the majority. Just that the advantages are marginal as the abs systems on bikes are, frankly, a bit crude. I’m not even recommending people remove it, only that it can be done, if anything I’m discouraging it. Also I’ve explained the bike is race only so that’s why I’ve removed it.Agree. If people don’t want to use ABS s expire it’s factually proven advantages for road riding that is their choice but they should not be saying that they are in the majority because they are not.
@Meccanico there is nothing wrong with opinions and I fully support and respect an individual's right to express their take on any subject; however, there is a significant difference between expressing an opinion and stating facts.Or just someone else’s opinion and as such should be respected.
@VehiCROS you may have missed the point, and you have done the same thing Meccanico did. You just made a statement as fact, which is incorrect. Motorcycles with ABS can have ABS in the front only with no ABS in the rear. Maybe we are to make assumptions about your statement, however, as stated you are incorrect. I have two Honda Groms in the garage with factory ABS on the front with no ABS on the rear. Maybe you were talking about the Scrambler, but you generalized your statement to all motorcycles.Meccanico clearly sees ABS the way I do!
as ABS bikes are not currently able to function with only front, however If possible I would have front only abs with option to disable but NO rear ABS.
That is Wonderful, I had to think about it, I suppose its pendant on the ABS system knowing when a wheel is actually "slipping", So good to know that some bikes have the option to disable rear ABS, Thanks for the info !In fact there are more bikes that can disable ABS on the rear wheel. Typically called offroad or supermoto mode. KTM has a few, and I bet BMW does too.
