1 - 14 of 14 Posts
2019 Desert Sled
Hey there all,
This is my first post on here.
I bought a 2019 Desert Sled off of copart for $4300. After copart fees and shipping to me I'm all in about $6000.
If you don't know what copart is it's an Insurace Auction site. The bike has a salvage title and not actual milage because it was vandalized and the the wires to the ignition were cut so they couldn't verify milage. It's also gotten tagged with spray paint. Bike seems like it's pretty good other than it was filthy once it got here. Not sure if that's from lots of Desert riding or just sitting on the salvage yard lot. I'm hoping I can replace wiring the harness, clean off all the black spray paint and get this bike looking good again.
Wheel Tire Fuel tank Automotive fuel system Automotive lighting
Hood Motor vehicle Automotive lighting Automotive tire Automotive design
Sky Wheel Tire Fuel tank Vehicle
Automotive tire Automotive lighting Hood Motor vehicle Automotive design
Sent from my SM-G986U1 using Tapatalk
2019 Desert Sled
Discussion Starter · #2 ·
Some more pics of the damage after a spray down with the pressure washer and removed tank.
Fuel tank Automotive lighting Vehicle Automotive tire Tire
Tire Automotive tire Tread Vehicle Wheel
Hood Automotive lighting Motor vehicle Automotive design Automotive exterior
Automotive tire Hood Automotive design Motor vehicle Sports equipment
Motor vehicle Hood Automotive tire Automotive design Automotive exterior
2019 Desert Sled
Looks like they tried to pry the gas tank open. When I took the tank off, I noticed it leaks from the fill port. Don't want water getting in my fuel if it gets rained on so I need to know...
Is this normal or is mine damaged?
This is awesome. Seems like a HELL of a deal considering the minor amount of work you'll need to do to it. The tank is vented beneath via breather hoses on the underside, not sure the cap is vented which makes me think your pry assumptions are correct. The cap has a rather large gasket around the inside, the screw driver or whatever possibly tore that up a bit. Have you been able to open the cap yet?
2019 Desert Sled
Discussion Starter · #6 ·
I was able to open the tank. The gasket doesn't look damaged but somethings not sealing right and the fuel looks dirty, possibly got some water or dust in there so that's getting dumped and replaced.
2019 Desert Sled
Discussion Starter · #7 ·
I would change fluids ASAP if I were you, just to be sure you're starting off clean. Here's a manual if you dont have one yet. This is an older one but most of the basics are gone over in detail.
Thank you so much for sharing, that will definitely help out a lot!!
If you need a gas cap I may have one. I bought mine vandalized as well but it had a lot less damage than yours but I needed to replace the locks so dealer sent me a new gas cap that I installed. I have the old one but its in great condition.
2019 Desert Sled
Discussion Starter · #10 ·
Yeah man that would be awesome... I wonder if I can swap the part with my key out. I'll pay for shipping if you're willing to ship it.
Im guessing you can, if they put it in there you can surely take it out and replace it with yours. Thats what I wouldve done but the dealership sells the entire thing when you buy the key and lock kit. Send me a DM we can chat about the details.
2019 Desert Sled
Discussion Starter · #14 ·
What happens when you join the all up and turn the key?
I imagine it should work fine. I plan to solder all the wires together as a temporary fix until I can find a used (or affordable new) wiring harness, just haven't had the time to put in work on the bike.
1 - 14 of 14 Posts
