Yeah,how?How the hell?
If done correctly, the weld will be stronger than the actual crankcase material.Hello
Ugly situation...
In mechanic, hammer is not the right tool. If a bolt doesn't go in, you first need to check alignment of the path it should go through.
Welding the crankcase is not the solution in my opinion. The crankcase is part of the frame solidity on a Ducati, I'm pretty sure that it won't resist after welding. In your case, I would look for a replacement engine. If you find a working one, just replace yours and sell it in parts to be refund. If you find a broken engine, but with correct crankcase, replace your crankcase and sell the rest of the parts of the other engine to be refund.
The entire frame is welded together...Hello
Ugly situation...
Amen brother!The older I get the lazier I am doing my own mods. I don't mind paying for the shop most times. I guess there are some positive aspects to becoming an old fart.
