Installed my Zard Zuma Special Edition Dark Exhaust and there's a squeak coming from the pipe when I hit the throttle. Haven't actually ridden it, just testing it out in the garage...idle is fine, hit the throttle and there's a high pitch squeak. (not continuous, just intermittent squeak)
I can confirm it's the db-killer because I took it out and tested...no squeak.
I can get the db-killer to move slightly with pressure from my hand, it moves maybe 2mm and sounds like a click in any direction, so I tried readjusting it by taking the snap ring out and back in...didn't change anything.
Before I permatex the darn thing I would like to see if there are other people, other than Bob from this forum, whom I've been in contact with with a similar experience, expect he glued it.
Maybe someone has figured out another solution? I know I can remove the db-killer but I'm afraid that will be too loud.
Thanks.
Thanks.
