If it was his steering bearings he would have known about it long before hitting a bump at speed.I would check the neck bearings for tightness before I would worry about the fork suspension causing a wobble.
Thats probably one of the funniest replies ive seen on a forum in quite some time Tc3. Lmao!I have had the shopping trolley slapper many times but was able to get control fairly quickly![]()
Rear end wobble is NOT considered a tank-slapper, it's commonly known as a "high-speed weave".The only time in my over 40 years of riding that a tank slapper occurred was due to my rear brake pads disintegrating at speed on my KZ900 caused the rear end to wobble out of control and for some reason I decided to apply hard front brake and that stopped me from crashing at over 100 MPH. So it DEFINITELY was not the front forks that caused the issue.
That may be but the handlebars were sure slapping against the tank.Rear end wobble is NOT considered a tank-slapper, it's commonly known as a "high-speed weave".
I agree with this.Is it possible that some forks are softer than others? (tolerances) as my bike so far has been super stable and feels really firm but never harsh.
Suspension performance will differ depending on a bewildering number of variables. A given riders weight, the road conditions, the degree of aggressiveness that the rider is capable of subjecting the bike to, the ambient temperature, etc.I agree with this.
I have never known another bike that has thrown up so many positive and negative views about the suspension. On the road my scrambler forks behave better than the fully adjustable showas on my last 3 Ducati's. The rear shock as new gave as good performance as my Ohlins did in the monster. After 3500kms the forks are still fine but I'll admit the shock is starting to fade in high temperatures. So i think this "budget" suspension varies significantly from bike to bike. Mine is definitely different from the test bike I took out. That is less precise and less damped than mine.
Let's just say they perform that way for "you" - and like I stated before, that should be all that matters.But they do Tony. Amazing isn't it.
I agree with that. Cripes I'm lucky with this bike, I'd love to try some of the other troublesome one's on this forum.Let's just say they perform that way for "you" - and like I stated before, that should be all that matters.
For MANY others, this simply is not the case.
I'm with you Stavely, no complaints about the suspension once it bedded in and I lowered the tyre pressure a bit. I reckon this bike was made for me. I'm only 70kg so maybe the stock setup suits us smaller blokes better, static sag is around 25mm and I'm using roughly 3/4 of the travel with reasonably quick riding through tight roads. Not a hint of a tank slapper and I've had the front wheel bounce off a branch while cranked over, front end just jumped sideways and held the line.I agree with that. Cripes I'm lucky with this bike, I'd love to try some of the other troublesome one's on this forum.
I am 74kg kitted out and hated the rear shock at factory setting but was a lil better at lowest preload setting. I ride a lot of country lanes that have poor road surface and I am real pleased I installed a rear M Shock as the difference is very noticeable when you hit bumps and pot holes. After installing the M Shock the front seemed more harsh but does not seem too bad now after a couple hundred miles so unsure if I will upgrade the front at all.I'm with you Stavely, no complaints about the suspension once it bedded in and I lowered the tyre pressure a bit. I reckon this bike was made for me. I'm only 70kg so maybe the stock setup suits us smaller blokes better, static sag is around 25mm and I'm using roughly 3/4 of the travel with reasonably quick riding through tight roads. Not a hint of a tank slapper and I've had the front wheel bounce off a branch while cranked over, front end just jumped sideways and held the line.
Just have to remember this is a forum and the number of people that have changed there suspension compared to the number that are happy with it in the real world is probably in the minority.
Tony, I'll buy your old used $34 shock for $25 plus shipping to Aus if you want to get rid of it, be nice to have a spare when mine eventually wears out.
Tell you what... You pay for shipping to AUS, you can have it for free!Tony, I'll buy your old used $34 shock for $25 plus shipping to Aus if you want to get rid of it, be nice to have a spare when mine eventually wears out.
Doc59 go for it! Then stick it on and we can compare the two and see if it is a variable quality issue.Tell you what... You pay for shipping to AUS, you can have it for free!
I disagree. I've said it before and I'll say it again.......coming from riding sports bikes all my life and the latest one which I also have being the Panigale, I've ridden the Scrambler hard and fast (not that I'm Valentino Rossi or anything but a half decent sports bike rider) and slow and smooth and everything in between. I've ridden it on smooth roads and really rutted, potholed, raised and sunken man hole covered roads. gravel roads and proper gnarly and nadgery roads. And its been fine.To quote Paul Thede "Suspension is what you know!" " You only know what you have ridden! It all depends on the rider and their abilities. What works for a fast rider is completely wrong compared to what works for a slow rider and vise versa. However, IMO the Scrambler is broke from the get go and doesn't work for anyone properly.
Thanks for the kind offer Tony. Sorry but I should have looked into it more before I said anything, Checked shipping prices from US to here and they are bloody expensive, especially combined with our lousy dollar at the moment. Works out more than I'm prepared to spend for something I don't really need. Sort of a pity because it would have been interesting to see if there was a different feel between the shocks as Stavely said. Shouldn't be really as they probably all come from the same factory.Tell you what... You pay for shipping to AUS, you can have it for free!
May be, there is some inconsistency between bikes?I disagree. I've said it before and I'll say it again.......coming from riding sports bikes all my life and the latest one which I also have being the Panigale, I've ridden the Scrambler hard and fast (not that I'm Valentino Rossi or anything but a half decent sports bike rider) and slow and smooth and everything in between. I've ridden it on smooth roads and really rutted, potholed, raised and sunken man hole covered roads. gravel roads and proper gnarly and nadgery roads. And its been fine.
Maybe it's because I am "average" build (just under 11 stone/150lbs/68kgs) that it performs well. But broke from the "get go" it most certainly isn't.
