1 - 8 of 8 Posts
Hey guys,
I adjusted my front suspension to the standard settings, which made it a bit more comfy to ride.
But on bad streets, with a lot little humps and bumps, I still get permanent shocks into the handlebars.
Is there an adjustment or setting, which will improve that?
Any info will be appreciated.
(Tried the forum search, didn´t find anything)
Well, the front isn´t sensitive at all on rougher streets, it doesn´t swallow anything.
So every bump is a vertical hit in the handle bar.
On a bad street and city speed it sometimes is a pita.
Your damping may be too slow, try backing off the compression and rebound 1 click then test it out.
Do the forks sag at all when you sit on the bike? Have you set the rear sag yet? The rear sag should be around 2"...
1 - 8 of 8 Posts
