1 - 4 of 4 Posts
I am noticing some brightness variations around the DRL ring (brighter on lower half, dimmer on upper) and have tried to find a solution. Does anyone know if you can change the DRL ring or do you need to buy the whole headlight unit to get it solved?
hmm im getting the same issue now. the top portion of the DRL ring is more yellow than the other sides. i've yet to find anything where you can just replace the actual ring. a new oem headlight is expensive as fuck!
I'm having this same issue. The upper half of the halo is yellowish. Were either of you ever able to find a solution other than a complete headlight upgrade?
Nope nothing yet. Doesn’t look like you’re able to replace just the halo ring. Don’t even see an oem part number for it.
1 - 4 of 4 Posts
