Bike came delivered with the baffle removed from the Termini race exhaust. Its a bit loud in our garage so thought I'd see how loud it is with the baffle/DB killer fitted. Managed to get the baffle in a position where it looked like the cap screw/securing screw hole lined up. Went to screw the carp screw in and hadn't quite managed to line up the holes so it wouldn't go it.
Upon trying to remove the screw from the little access hole it fell inside the can. To me, it looks like the only way to recover the screw is to remove the can and tip it upside down. Looks like its just a case of remove 1 mounting bolt holding the can onto the swingarm and a spring clamp from can to exhaust pipe. Removing these should allow me to remove the can won't it?
Has any one else been daft enough to have this issue and have a simpler solution since I don't have grips to remove the spring?
Cheers
Cheers
