1 - 5 of 5 Posts
Hello all,
I was wondering who here that has a scrambler 1100 can help with with a traction control issue. I'd like it turned off completely and I'm wondering which level (1-4) is "off"
TIA
Alex
It should have a - where the numbers go. 1 is the lowest traction control setting. The - is off
If it is turned off correctly you should have a constant traction control light up orange on the cluster.
Yup exactly, set the DTC indicator to a “-“ then you will get a orange circle:triangle on the dash lights indicating dtc is off.
what issue are you having with it enabled?
Hello all,
TIA
Alex
I’m curious what issue your having as well. I actually prefer to ride it in TC 1 as it hardly interferes unless I’m off-road.
1 - 5 of 5 Posts
