CLASSIC
803 CC
The Classic version is aimed at those who appreciate attention to detail and 1970s style, but who don’t want to compromise on riding pleasure and the functionality of a modern bike. It is characterised by unique, refined details, such as the aluminium front and rear mudguards, the spoke wheels and the brown seat with diamond-shaped inserts. In Orange Sunshine.
- Pirelli Dual Sport Tires
- Vintage Seat
- Aluminum Fuel Tank Covers
- Tear Drop Steel Fuel Tank (13.5 lt)
- Spoked Wheels (18" front - 17" Rear)
- Aluminum Belt Covers
- Aluminum Heat covers
- 803cc L-Twin cylinder 75hp, Desmodromic Air Cooled Engine
- High and Wide Handlebar
- Round Headlight with LED Ring
- Semi-Floating Mono Disk Radially Mounted Monobloc Brembo caliper 4-Piston, Up Front
- ABS Standard
- Color: ORANGE SUNSHINE
- Aluminum Stripe Under Seat
- Aluminum Front/Rear Mudguard
- Single Kayaba Shock Absorder with Preload Regulation
- Passenger Grab Rail
- LCD Dashboard with Interchangeable Aluminum Cover
- Black Fuel Tank Stripe
- Under Seat USB
- New Tech LED Tail Light
- Plate Holder
Engine
Type: L-Twin, Desmodromic distribution, 2 valves per cylinder, air cooled
Displacement: 803 cc
Bore x stroke: 88 x 66 mm
Compression ratio: 11:1
Power: 55 kW (75 hp) @ 8,250 rpm
Torque: 68 Nm (50 lb-ft) @ 5,750 rpm
Fuel injection: Electronic fuel injection, 50 mm throttle body
Exhaust: Exhaust system with single stainless steel muffler, aluminium silencer cover, catalytic converter and 2 lambda probes
Emissions: Euro 3
Transmission
Gearbox: 6 speed
Ratio: 1=32/13 2=30/18 3=28/21 4=26/23 5=22/22 6=24/26
Primary drive: Straight cut gears; Ratio 1.85:1
Final drive: Chain; Front sprocket 15; Rear sprocket 46
Clutch: APTC wet multiplate with mechanical control
Chasis
Frame: Tubular steel Trellis frame
Front suspension: Upside down Kayaba 41 mm fork
Front wheel travel: 150 mm (5.9 in)
Front wheel: Spoked Wheel, 3.00” x 17”
Front tyre: Pirelli MT 60 RS 110/80 ZR18
Rear suspension: Kayaba rear shock, pre-load adjustable
Rear wheel travel: 150 mm (5.9 in)
Rear wheel: Spoked Wheel, 3.00” x 17”
Rear tyre: Pirelli MT 60 RS 180/55 ZR17
Front brake: 330 mm disc, radial 4-piston calliper with ABS as standard equipment
Rear brake: 245 mm disc, 1-piston floating calliper with ABS as standard equipment
Dimensions and Weight
Wheelbase: 1,445 mm (56.9 in)
Rake: 24°
Trail: 112 mm (4.4 in)
Total steering lock: 35°
Fuel tank capacity: 13.5 l - 3.57 gallons (US)
Dry weight: 176,5 kg (389 lb)
Wet weight*: 192,5 kg (424 lb)
Seat height: 790 mm (31.1 in) - low seat 770 mm (30.3 in) available as accessory
Max height: 1,150 mm (45.3 in) / brake reservoir
Max width: 845 mm (33.3 in) / mirrors
Max length: 2,100 - 2,165 mm (82.7 - 85.2 in)
Number of seats: Dual seat
Standard Equipment
Spoked aluminium wheels, front and rear aluminium mudguards, vintage design seat, fuel tank with black stripe, high plate support, dedicated logo
Price
Classic $9,995 (USA), $10,995 (Canada), $149,990 (Mexico)
