URBAN ENDURO
803 CC
The Urban Enduro version is the ideal companion with which to get around urban obstacles with agility, but also to reach new places, riding on the less travelled roads. The brown seat with a ribbed design, lined with technical fabrics, offers first-class ergonomic comfort. The fork protectors, engine sump guard and the headlight grille protect the key parts of the bike on off-road sections, while the cross bar stiffens the wide handlebar. Additional references to the off-road world include the high mudguard in plastic fibre and the spoke wheels. In Wild Green.
- Tear Drop Steel Fuel Tank (13.5 lt)
- Ribbed Seat
- Aluminum Fuel Tank Covers
- Fork Protectors
- Higher Front Mudguard
- Pirelli Dual Sport Tires
- Spoked Wheels (18" Front, 17" Rear)
- 803cc L-Twin Cylinder 75hp, Desmodromic, Air Cooled Engine
- Aluminum Heat Covers
- Aluminum Belt Covers
- Off-road Handlebar with Cross Bar
- Headlight Grille
- Round Headlight with LED Ring
- Color: WILD GREEN
- Skid Plate
- Semi-Floating Mono Disk Radially Mounted Monobloc Brembo caliper 4-Piston, Up Front
- ABS Standard
- Aluminum Stripe Under Seat
- Single Kayaba Shock Absorder with Preload Regulation
- Passenger Grab Rail
- LCD Dashboard with Interchangeable Aluminum Cover
- Under Seat USB
- New Tech LED Tail Light
Engine
Type: L-Twin, Desmodromic distribution, 2 valves per cylinder, air cooled
Displacement: 803 cc
Bore x stroke: 88 x 66 mm
Compression ratio: 11:1
Power: 55 kW (75 hp) @ 8,250 rpm
Torque: 68 Nm (50 lb-ft) @ 5,750 rpm
Fuel injection: Electronic fuel injection, 50 mm throttle body
Exhaust: Exhaust system with single stainless steel muffler, aluminium silencer cover, catalytic converter and 2 lambda probes
Emissions: Euro 3
Transmission
Gearbox: 6 speed
Ratio: 1=32/13 2=30/18 3=28/21 4=26/23 5=22/22 6=24/26
Primary drive: Straight cut gears; Ratio 1.85:1
Final drive: Chain; Front sprocket 15; Rear sprocket 46
Clutch: APTC wet multiplate with mechanical control
Chassis
Frame: Tubular steel Trellis frame
Front suspension: Upside down Kayaba 41 mm fork
Front wheel travel: 150 mm (5.9 in)
Front wheel: Spoked Wheel, 3.00" x 18"
Front tyre: Pirelli MT 60 RS 110/80 ZR18
Rear suspension: Kayaba rear shock, pre-load adjustable
Rear wheel travel: 150 mm (5.9 in)
Rear wheel: Spoked Wheel, 3.00” x 17”
Rear tyre: Pirelli MT 60 RS 180/55 ZR17
Front brake: 330 mm disc, radial 4-piston calliper with ABS as standard equipment
Rear brake: 245 mm disc, 1-piston floating calliper with ABS as standard equipment
Dimensions and Weight
Wheelbase: 1,445 mm (56.9 in)
Rake: 24°
Trail: 112 mm (4.4 in)
Total steering lock: 35°
Fuel tank capacity: 13.5 l - 3.57 gallons (US)
Dry weight: 176 kg (388 lb)
Wet weight*: 192 kg (423 lb)
Seat height: 790 mm (31.1 in) - low seat 770 mm (30.3 in) available as accessory
Max height: 1,150 mm (45.3 in) / brake reservoir
Max width: 845 mm (33.3 in) / mirrors
Max length: 2,100 - 2,165 mm (82.7 - 85.2 in)
Number of seats: Dual seat
Standard Equipment
Spoked aluminium wheels, aluminium engine sump guard, high front mudguard, headlight grill, aluminium handlebar cross-strut, front stem protectors, ribbed seat, dedicated logo
Price
Urban Enduro $9,995 (USA), $10,995 (Canada), $149,990 (Mexico)
