1 - 4 of 4 Posts
Only had my icon out a couple of times since i got it in december
and have noticed the engine oil has gone white just wonderd if anyone else has had this problem
Bike was only serviced just before i got it so has new oil and filter
Take longer rides (and possibly block the oil cooler). You oil is not getting up to temperature and emulsifies with condensated water.
Common problem on oil/air cooled engines. They stay too cool at winter temps...
Don’t panic. I changed my wifes Diavel’s engine oil and filter when I fitted the see through clutch cover, the oil went milky as soon as I started the bike up. Shahoor! It looked awfull through the window and took 3-4 full heat cycles to clear. (I couldn’t take it for a hot run)
1 - 4 of 4 Posts
