Has anyone experienced problems with excessive lash in the driveline?
It appears to be inside the trans/engine. The Cush drive and chain are all good. Before I pull off the side cover to inspect the clutch and primary drive, I wanted to see if there have been any other cases of this.
It could just be an issue with stacked tolerances all the way from the output of the trans back to the primary but it still seems excessive to me, as it becomes and issue when coasting and then shocking the driveline when giving it some throttle.
