so I'm trying to remove the full exhaust to get ceramic coating and the last nut for the vertical pipe is dam tricky.
I'm checking in to see if anyone has done it, and if so, what did you do to get it off - the inside one, all the rest are pretty straight forward.
I'm thinking maybe the battery box needs to come out, or shift up a little - but all that ABS stuff looks like I should leave it alone before I stuff something up.
If you have done it, please share - the $8 manual doesn't offer much in regards to what needs to happen before getting the pipe off.
