Hum, "U' bend; Like the way you think. Being smaller it'll be lighter, maybe not all that bad, and the ECU upgrade should help performance and is probably why it's so expensive. Sure sounds good.Thats what I have coming. Says it has a upgrade key. That must be a ecu plug in then maybe. That cat could be eliminated by someone with just a U bend
I doubt very much if the "cat tumour" is any sort of cat at all. More likely a chamber to provide some silencing and maintain the volume of the exhaust system. Cutting it out might be a bad idea.Thats what I have coming. Says it has a upgrade key. That must be a ecu plug in then maybe. That cat could be eliminated by someone with just a U bend
The cat on the standard exhaust is integrated into the silencer. It would be possible to cut it open, remove the cat element and weld it closed again as some MTS owners have done.Not having looked closely under one, is it possible to remove the cat with a short link pipe? I know a pipe maker and it'd be a nice way to lose a fair chunk of weight.
Are you referring to the stock one that comes on the bike (except the FT), or the Termi one that 62Yellow posted above. I know the stock one has a cat, and my comment above yours was referring to the Termi one. I assume you are talking about the stock exhaust, but if you are also referring to the Termi one, where is the spec sheet that says it has a cat?It's listed in the spec sheet as a cat. It's just a question on if you can bypass and remove it, or the whole silencer unit needs replacement?
