so booked in for first service this weekend when I was on 600...
Currently sitting at 1000
Hey you better go ride 20 miles!Mine goes it for it's first service this evening. I should be at 605 miles when I pull into the dealership.
After that... the gloves are off! :headbang:
Good to know! Thanks for the tip! I'm at 506 miles right now, and was going to do about 90 miles after work, and then head over to drop it off. I'll leave myself some spare time to get in enough miles so that light will turn on.Hey you better go ride 20 miles!
The service light goes on at 623 miles. (At least mine did.) If you don't get past that, it will go on after your service!!!
OK...since you brought up "pushing the limits"...I have noticed, I think (as a glancing observation), the the red lights and rev limiter come on earlier in lower gears than higher gears.Rode it like I stole it from the get go![]()
Not really sure, seems to always top out around 8OK...since you brought up "pushing the limits"...I have noticed, I think (as a glancing observation), the the red lights and rev limiter come on earlier in lower gears than higher gears.
Anyone else notice this? Or anyone who reads the manuel remember any such thing?
Or is it just my imagination...
There is no "redline" mark per se on the tach.
I think it is variable, lower in lowest gear and higher in upper gears.
I've even noticed how much more willing the motor is after my current 450 miles, seems like its starting to loosen up and not feel as "tight".Yes make sure you go the extra miles. YOU HAVE TO DO 623 plus. Its not critical over but under they CANNOT turn off a light that's NOT ON.
I am now on 995 and still not opened her right up but am free revving it. She goes well.
You mean I wasn't supposed to hit 7K yetMy service indicator came on at 630 from memory? Booked in next Friday, then I can up the revs to 7,000 for the next 1,500 miles ;-)
Only if it's an emergency, like when the light goes green. :headbang:You mean I wasn't supposed to hit 7K yet![]()
Rev warning at 8,900 and limiter at 9,200 no matter what gear you are in.Not really sure, seems to always top out around 8
