Here's a tip or observation I have found since fitting my Rizoma indicators front and rear to my Icon.
Firstly I did these a couple of weeks ago and they fitted nice and neat after I replicated the shape of the fix brackets but the front ones are awkward to do because the connectors are halfway under the tank and fiddly to do but I assure you it is able to be done by a general competent person. The reason I did go to the trouble of lifting the tank is
1/ I don't like cutting OEM parts apart to splice connectors in
2/ I had Rizoma indicators with specially bought Ducati connectors for it.
The rears are easy and just undo the 6 bolts holding the tail tray off and the connectors are viewable.
So here's where it got complicated. I had the resistors from the last bike my Monster 1100s and they had 1 per indicator to give correct flash rate but they also advise they could need up to 2 per indicator. So following that pattern it was done 1 per indicator and they worked but were flashing too fast for my liking but ok.
Next thought was I then need 2 per indicator then so ordered 4 similar from ebay and only £6 for 4 so not dear.
They came today so removed the rears as access quick and plugged on the extra ones. Hmmm still flashing the same rate. I then tried using the 2 Rizoma ones. Same thing flashed same rate. I then took the resistors off the rear and they flashed normal even with one on the front.
So there you are YOU DONT NEED RESISTORS it seems. I know that modern electronics have the flasher relay built into the ecu so maybe its smarter even more now and senses it.
if I can be bothered I may still lift the tank again to remove the front resistors to see if they slow down more. I doubt it will make much difference.
