Even as a noob, I can tell the footpegs are crap. Lots of discussion on what fits and how to fit, but which seems to be the better of the two? I know price is about half for the Multistrada. Thanks.
Sean
Sean
I can confirm that that the Abba Lift does not work with Motech footpegs fitted. The way around the problem with standard pegs is to insert something under the peg to hold it in the folded position however with Motech the pegs need removed altogether. I may still use Abba on the Scramblers if for some reason I need both sets of wheels off at the same time.A cautionary tale. I bought an Abbastand for my Classic some months ago and tried it for the first time yesterday. The Multistrada1200 footrests are too long and wide to enable the stand bobbins to fit inside the swing arm pivots, and the stand will not operate : whether it will work with the SW Motech rests I know not, but I do not intend buying a set to find out. I shall need to use a paddock stand with spindle bobbins, as I do not intend to re-fit the old footrests.
I contacted Abbastands and had a very prompt reply, but it seems that there is no solution to the problem, having regard to the differences in the footrests' dimensions: yet another example of size matters ------
I
Hello Hui ,where did you get the stand from ,I think /know it will transform my work place .
rangerover
Constands type lift is the answer to all this but I found it still comes with it's own problem.
ie. When the bike is lifted I did not like the fact it leant away from vertical to the right. The fix, for me at least, was to taper the metal block between the main post (black) and the bike mount plate, this can be seen in the photo, once this is done, in my opinion it's better than all other options.
View attachment 13625 View attachment 13633 View attachment 13641
