1 - 4 of 4 Posts
I’ve just refitted mine and without checking, from memory they are 36Nm. And yes grease them. Don’t use normal grease use anti seize grease such as copper slip.
Yeah, around 40Nm
Btw, make sure you align the caliper before you torque it down: screw the bolts in all the way except for the last half turn, so the caliper can still wiggle a tiny bit. Grab the front brake lever firmly, and keep it like that (zip tie, or long arm), and only then tighten the two bolts.
1 - 4 of 4 Posts
