Hi Scramblers just an update on the removal of the screw 5M worm screw that sits in the stub off the fork Leg.
I saw a video that said you had to use a 3 mm drill bit to drill out the 5M Worm Screw.
So I tried this new approach.
I took a 3 mm hex/allen nut and gently tapped it into the 5M worm screw.
Then I took my drill and with some very careful attempts it worked.
Have a look at this video.
