1 - 5 of 5 Posts
Hi everyone,
My number plate broke off (poorly installed tail tidy...) and the light must have shorted, the wires are frayed. The rear light, brake light and horn are no longer working.
I presume a fuse has blown, does anyone know where it's located? I can't find anything online.
Thanks!
Found the fuses, that's not the issue 🤨
Any other ideas welcome!
Probably a stripped/pulled wire or plug. I'd start with the tail light; unplug and confirm that it works. Then work back into the wiring harness.
The number plate is prone to loosen up. Even with blue loctite I lost a few parts (but never had the whole thing come loose). I replaced the Ducati lock washers with regular lock washers and that seems to have done the trick.
I had repeated problems with that 15A-fuse blowing whenever the bike was heated up from riding and got wet. Even in heavy rain. To me it seemed that the steam condensated somewhere and caused a shortcut. Replaced the horn and the tail light. Never found the source of the problem. Traded the bike in ...
1 - 5 of 5 Posts
