1 - 5 of 5 Posts
Hi - Does anyone know the recommended torque setting for the upper handlebar clamp bolts (for my 1100 Sport)? I can't seem to find it anywhere. I'm replacing a couple of the bolts with a Ram mount ball, and an accessory socket bracket, and would rather use the correct torque, than simply going by feel. Thanks.
It should be about 22nm. Just check on the other 3 bolts starring at 20 to be sure though. When I did my ram mount I remembered that it was hard to torque it down to the exact number so I ended up going a little less.
Discussion Starter · #4 ·
Quite pleased with the result. I haven't put the Ram ball on yet (I'm using a cheap Chinese Ram claw clone at the moment for the SP Connect phone holder), but the SW Motech accessory socket bracket works well there. I've removed the USB socket under the seat, as I'll never use it, and used it's plug to provide a switched live to the relay in the fuse block.
1 - 5 of 5 Posts
