Being 5'3" I find the bars on my FTP are making my wrists ache. Would higher bars help and if so should I get those from the DS or are there more cost effective options.
Thanks for your responses.
My current situation is standard FTP bars.
Am a bit concerned that risers may impede my view of the speedo etc (from an earlier post).
Adjustable bar clamps.If possible please could you let me know which ones would fit straight on my FTP?
Also do you know how to get look up a topic (eg handlebars) on this forum?
Standard Icon bars - aren't they higher than the FTP? Where are you located I just took some standard bars off.
The two sizes used are 28mm / 1"1/8 and 22mm / 7/8"Point of note - FTP mounts are 1 inch and all others are smaller I believe.
Scratch that - I was thinking of the FT. Not sure about FTP.
Sent from my SM-G900I using Tapatalk
If you are going to buy handlebars then make sure of the size first. There are ways to convert to either or but gets expensive if it's just an experiment.Thanks anyway.
Please excuse my ignorance but can you explain what that means in general?
I stand corrected. Thought FT was 1". I was doing it wrong.The two sizes used are 28mm / 1"1/8 and 22mm / 7/8"
I believe Harley Dangerous uses 1" or at least they used to.
I'm 5'4" and I use ultra low renthals. No wrist issues.Being 5'3" I find the bars on my FTP are making my wrists ache. Would higher bars help and if so should I get those from the DS or are there more cost effective options.
