can you use motorbikes in the dark ?![]()
Funny I was just reading all about this earlier today without seeing it on here,,, I've had a HID kit on a car before and it was quite cumbersome to fit the ballasts event with all the engine bay space. I also had to drill the cap of the rear of the light to fit the cables - so I was looking at some Philips Xrreme Vision 130 instead - trying to get a better light plus something more white light xenon.Some yes, this one, not so much.
I see a HID conversion on ebay, I may need to be the guinea pig
Sounds painful!ok,
Question sent to ebay seller,
New message to: ninjazx9rblue
Hi, Can you tell me how this fits the scrambler, specifically,
where does the ballast mount,
is ballast mounting hardware supplied,
is it plug and play or do wires need to be cut and joined,
Thank You.
Answer received,
New message from: ninjazx9rblue(8,323
Hello, Bulb is a straight swap for the original. It is not necessary to cut into any wires. Plugs direct into existing headlight plug on bike. Then one wire to earth and one to battery live. Kit supplied with extension leads and hardware,cable ties for mounting ballast under tank etc out of sight. Full instructions are supplied for Naked bike like the scrambler. Regards
Tyre Shredders Road and Racing.
Trick Motorcycle Parts and Accessories.
07957 891 640
