41 - 60 of 60 Posts
I do a fair bit of riding in the dark because of my work schedule, and fog makes regular appearances where I live, so I went the auxiliary LED route. I got the Denali DM micro with inverted fork mounts. Not the sexiest thing ever, but visibility is much improved, and drivers definitely notice them during the day, too.
· Premium Member
All I installed the Philips X-treme 130 bulb - brighter and whiter - BUT - the rear of the bulb is longer than the OEM bulb and you can not put the cover back on correctly.
You can get the screws to start - but that's it.
So just be aware - not sure if there is any other high output bulbs that are same as standard bulb. - I will need to look about some more.
Anyone fitted any?
For now I have the cover on and sealed it with some silicone around the gap as a precaution - but not ideal long term.
· Premium Member
I hear that they are going to re-brand Denali as McKinley.
Wow, I just caught this.
Well played, sir.
· Premium Member
Anyone fitted any?
Totally correct, found this out "the hard way", this evening.
I took so some self-setting silicone rubber, and made a thick "gasket" to fill the space, then used longer screws.
I realize I'm being "anal", but it really bothered me that the stock H4 bulb was a different color temperature than the LED ring.
Matches well now.
I had the same problem. After a quick search on internet I found that there are two standard for the H4 socket: P43t-38 and P43 (or Px43t), the first one being longer (see List of automotive light bulb types - Wikipedia, the free encyclopedia). Then I bought an Osram Night Racer, but not yet mounted.
I've had the 7" led headlight on my previous HD Iron and it was pretty decent. Very helpful in night riding situations with no blind spots and adequate light spread. It was definitively an improvement over stock. I'm wondering right now if somebody has tried to fit this on the Scrambler.
one year on and theres loads more options with the LED bulbs, has anyone added a LED H4 Bulb that isn't a Cyclops ?
41 - 60 of 60 Posts
