Got the same results with the Osram Night Racer 110. More and whiter light than the standard bulb. NIGHT RACER 110 | OSRAM Automotive
You need the H4 version, part # 64193NR1.
Hi!!!! You need to remove the back cover or modify something to fit this bulbs?? I want to change my headlight bulb to another whiter and brighter, but all i see needs to modify or remove the headlight back cover.
No, you don't need to modify anything to the headlight unit.The back cover will only be a bit tighter since the connector side of the new bulb is a fraction longer than the original bulb. But you still can get the cover watertight closed without excessive screw force or braking the cover.
You may want to look for a duo-pack of these bulbs: cheaper per piece and you have spare one. For example: OSRAM Night Racer 110 Halogeenlamp H4 60/55 W.
It's not so obvious from that page but it is really a pair of bulbs.
Related Threads
Ducati Scrambler Forum
99.3K posts
12.8K members
Since 2014
A forum community dedicated to Ducati Scrambler owners and enthusiasts. Come join the discussion about performance, accessories, exhaust, reviews, troubleshooting, maintenance, and more!
