Do you like this headlight
  • Yes ... Go for it
    Votes: 14 50.0%
  • No ..Stick with the OEM
    Votes: 14 50.0%
1 - 20 of 102 Posts
Can you take some before and after photos at the same spot... please
Also interested in some dimensions off the back... to see if it would fit as is to the 1100? I think not as I think the 1100 has 5 wires and an auto light sensor..
THANKS
THANKS
If you go the the web site there are photos of the back of the unit. it appears to be identical to the OEM light with the exact same plug.
Yes - but 1100 is slightly different.... hence the request for some dimensions...
Electrical plug is on the right with 5 wires.
Mounts using the same style pivot mechanism... but may well be at different position.
So photos of the back with key dimensions would be good..
1 - 20 of 102 Posts
