1 - 5 of 5 Posts
well, first of all, it should be possibile.... this is the good news...
the bad nwes are that handguards mounting kit, according to Murphy's, need just the handlecross bar brackets spots...... and..... I actually cannot remove the bar ends..... after easy unscrew the m5 bolt..... nothing... I really don't know how to remove the small bar ends... it looks they are pulled inside the handlebar by a lot of pressure....
pls help....
Discussion Starter · #5 ·
ok, finally I was to my dealer for Multistrada open week end, and I asked how to remove end bar; the correct way is:
loose the nut but don't remove it, than carefull hit the nut inside the bar end, the inner expanding bolt will close and it will immediately pop off
1 - 5 of 5 Posts
