Need some help on my 2019 Full Throttle. I noticed my headlight started flickering about a week ago and started doing research. Found online a connection is most likely loose.....which makes sense and obvious. Unscrewed the 4 nuts holding the lamp and found the culprit. Seems like the one connection to the back of lamp which has about 5 wires connected to it is faulty......thinking one of the wires were pulled. Not sure how to disconnect. Don't want to pull as I'm sure it'll rip all the wires. Anyone been able to disconnect cable. Look at images attached.
Thank you for any help or guidance given.
Best,
George
Best,
George
