A month ago I was on my way home and started having major issues with clutch slippage. It was to the point where the bike could be in gear and it felt like neutral. I tried all the adjustments but nothing worked. After some people advised (and reading this forum) it seemed clear that the clutch needed to be rebuilt at only 6,700 miles. Sure enough, when I opened it up, the plates had some severe wear.
After a bunch of hurdles, I put in a new full set of Adige plates (oem), checked the bolt tensions about 10 times and everything seemed fine.....
Until I turned the bike back on.
As soon as I put it in 1st gear, it did engage a little bit but I can still push it around similar to neutral. Yes, I've checked the line and adjusted everything probably 25 times. NOTHING seems to be working and there's still no power to the rear wheel. (the chain and sprockets are all in good condition)
Has anyone out there had this problem or heard of it?? Any advice?
thanks for your help
